Fault Code "Lo"
Has fault code Lo right after turning key on. Found out code means battery consumption too much. What does this mean???
  • Posted 2 Oct 2020 00:45
  • By MikeHLT
  • joined 17 Aug'16 - 5 messages
  • Michigan, United States
yes it means the battery voltage is low
when the line contactor is closed the system is seeing voltage below 22v.
the logic card needs to see correct battery voltage at connector pin locations CN2-34, 39, 40, 41, 42.
have your battery tested and make sure all the cells are ok, a couple of bad cells can cause a severe drop triggering this code.
  • Posted 6 Oct 2020 07:38
Usually means the system detected battery voltage below 22v.
  • Posted 6 Oct 2020 05:39
  • By BLey
  • joined 31 Jul'20 - 60 messages
MAXAM Tire, Inc.
UN Forklift FD20-35FJM3
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
