Fault Code 522655-1
Will only start with starting fluid. This is the only code that comes up. Any help pointing me in the right direction will be greatly appreciated.
  • Posted 27 Aug 2020 04:10
  • By teeboe
  • joined 27 Aug'20 - 1 message
code means its running too lean. id suggest checking LPG filters / regulator and check wiring code also suggest low fuel pressure issue so check converter hope this helps cheers
  • Posted 25 Sep 2020 16:39
  • By Applez
  • joined 25 Sep'20 - 3 messages
  • Victoria, Australia
