Hyd codes
Changed batteries on this unit and now the hydraulics aren't working. Coded read ad follows, h0116, h0216, h0316, h0416, and h1028.
  • Posted 8 Jul 2020 23:45
  • By Flaj76
  • joined 8 Jul'20 - 5 messages
with that many codes i would be looking at the harness, for a break or bad ground wire
  • Posted 13 Jun 2021 12:46
  • By jimbony
  • joined 19 Feb'19 - 19 messages
Hi, my forklift is showing the following error codes:
E0146
01690
Can't find these error codes anywhere online. Do you know what's the problem?
  • Posted 11 Jun 2021 06:10
  • By Dale_Dindial
  • joined 11 Jun'21 - 1 message
  • Guyana
Thank you Fishmech, that took care of the problem.
  • Posted 11 Jul 2020 10:36
  • By Flaj76
First you need to calibrate hydraulic handle. Turn key on, do not start truck. Do not know the age of the truck so I am assuming you have a joystick. Push joystick forward and hold for three seconds, let go to center for three seconds and pull back and hold for three seconds. Do the same for the tilt. For any other truck I will need serial number. The last code you list is an External PVE Fault. Below are the specifics. Could be failed connections or wire or valve. Looking at the hydraulic valve, you should see one with a red light. Good Luck
Input signal monitoring (flashing red LED on valve) Transducer supervision (constant red LED on valve) Supervision of the closed loop (constant red LED on valve).
  • Posted 10 Jul 2020 04:14
  • By Fishmech
  • Virginia, United States
