Error code 153
Hi
we have a BT RR B2 reach truck s/n 731823 that intermittently comes up with error code 153
We found if you turned the hydraulic motor by hand slightly the error went away, so suspected the encoder bearing in the hydraulic motor and changed it, it seems that that has not cured it
Any pointers to what it may be?
Many thanks
PS changed a encoder on a yale pallet truck recently using one from TVH and it turned out to be bad, could it be a bad one again?
  • Posted 2 Jul 2020 00:14
  • By P_E_G
  • joined 30 Jan'13 - 78 messages
  • Kent, United Kingdom
paul(at)gandgforklifts(dot)co(dot)uk
Hi,
Program the value of 17 to "0" in parameter and check.. is the same problem repeating.
  • Posted 11 Aug 2020 15:54
  • By manjunath_m
  • joined 22 May'19 - 10 messages
  • India
inforklogisticssolutions@gmail.com
Hi,
Program the value of 17 in parameter, is the same problem repeating.
  • Posted 11 Aug 2020 15:53
  • By manjunath_m
  • India
Board for pump (a2 board) problem from soket
  • Posted 8 Aug 2020 13:22
  • By Mohd_Suzieameer
  • joined 8 Aug'20 - 2 messages
  • Johor, Malaysia
Ameer
Mitsubishi FGE35AT
Maxlion FD50T
RAEDER-VOGEL
