Will not move lifted.
When the lift is in raised above about 6" position it will not travel forward or backward.
  • Posted 13 May 2020 23:10
  • By Bobby_Brown
  • joined 13 May'20 - 8 messages
Thank You
  • Posted 27 May 2020 00:50
  • By Bobby_Brown
check your elevation switch and also check the pothole switches and linkages.
the elevation switch in the scissor linkage will be closed when stowed and when it goes over 6" it opens and the pothole switches change to closed position and keep the travel enabled when they lower when you elevate the platform keeping the travel function enabled.
  • Posted 14 May 2020 23:37
  • Modified 14 May 2020 23:38 by poster
