Crank and No Start, No Spark
G424E Engine. Ran thru manual several times to see if Im over looking anything, seems to be a rather easy and straight foreward engine.
No Codes.
CEL on after key on, according to G424E manual it should turn off.
New ECM
New Smart Coil
New Crank Sensor
No Spark out of smart coil.
Verified my 12v and grounds. Only thing I do not know is im not sure what signal I should see on the Coil Driver wire from the ECM at the igntion coil 5v or 12v and pulsed or constant?
Checked wiring between crank sensor and ECM. OK
Checked wiring between ECM and coil. OK
12v at coil good, grounds good. No blown fuses. Relays seem to test good.
I have 3 questions
1. What signal I should see on the Coil Driver wire from the ECM at the igntion coil, 5v or 12v and is it pulsed or constant?
2. What is the XDCR? Were does it come from and how does it play into this system? Seems to be a 5v transducer of some sort.
3. What else in this system could be preventing this from starting.
Dont ask about a laptop cause one one here is a dealer nor would have one. Small island...
  • Posted 9 May 2020 06:13
  • By Pocho86
  • joined 9 May'20 - 1 message
  • Hawaii, United States
I have the same type forklift with a brake problem. Maybe we can help each other.
You say yours won't start. This is probably a pretty basic answer but you gotta start somewhere.
These forklifts run on both gasoline and propane. At least mine does. If yours does too, it has a switch to select which fuel to use. If it's turned towards the wrong fuel that you don't have any of... It won't start. So if that's it hers what to do.
Open the bonnet and stand on the left of the vehicle (opposite the control arms) look back towards the radiator and just to the right of it there should be a selector switch. One setting is for gas I believe it's turning the selector left or counter clockwise and it's marked petrol or gasoline. If you turn it right or clockwise it selects propane. Make sure you have it on the correct fuel source and have that fuel onboard.
If it's propane if course open the valve at the propane tank as well.
The gasoline cap is the red one on the right side of the forklift body under where the bonnet meets the body. It's red plastic and looks strange.
Make sure your fuel source and the selector are in sync. I didn't know ours ran on two fuels at first. Try that then you have a starting point. Also check the plug that goes into the coil sometimes the connector in the wire end comes loose. Make sure it's crimped real tight.
Now mine loses brake pedal when I lift the forks with a load on them. Any idea what caused that? Possibly a bad brake valve? I'm new to this wet disk brake system.
  • Posted 21 Jun 2024 22:59
  • Modified 21 Jun 2024 23:05 by poster
  • By Kirk1185
  • joined 4 Feb'24 - 5 messages
Kirk B.
Hi dear friend how are you.
I have this problem.
Do you solve it?
  • Posted 21 Jun 2024 02:49
  • By Afshin
  • joined 29 Aug'23 - 34 messages
  • Iran, Islamic Republic Of
UN Forklift FBT18NQZ1
Manitou M50-4
VETTER Forks, Inc.
Oxford Ct, United States
