SCR CARD IC3645 LXCD1
hello technical
I have scr card IC3645LXCD1.
I need the LXT Dash Display to see the fault.
I can buy where it.?
the problem that I have is that forward and reward do not activate coil. I have realised all the possible measurements and there is nothing badly. until I have changed the 3645. I not that it happens
thanks
  • Posted 14 Sep 2008 11:49
  • By fabio01
  • joined 31 Jul'08 - 12 messages
  • uruguay, Uruguay
you need the EV100LX analyzer handset
they sell them on ebay
not cheap but you can program a new card with it if you have to replace it
try a tvh dealer too
you should have battery volts at the coils positives (wire 15) when the seat sw , brake sw (pedal released), and accelerator switch is closed
after the coils the negative path to ground is through the card on pb4 (wire 27 forward) and pb5 (wire 23 reverse)
try cleaning the plugs with nonconductive electrical parts cleaner
but it will help a lot to know the code
  • Posted 15 Sep 2008 03:23
  • By justinm
Toyota 02-8FD25
Terberg YT222
