Tramsmission
I have forward hear..when I putle we to neutral it wants to move in reverse slightly,when I'm reverse it starts to move them stops...had valve body off and Valvea..didn't see any thing obvious..but some on has had it apart....I swapped rev amnd forward valves and selonoids...I have power to them in reverse and fioward....the emblem on the side says it is a gtd060.....can any one steer me in the right direction...maybe flow chart,parts list to see if valves. Are in right
  • Posted 27 Mar 2020 14:23
  • By Skipsfab
  • joined 27 Mar'20 - 2 messages
Thank you for the info..I thought it wasclutch pack....how. Costly is replacing them and how much time
  • Posted 28 Mar 2020 07:21
  • By Skipsfab
Test forward and reverse clutch pack pressures if same and no drive you have clutch pack worn out. if you have zero pressure when in neutral and truck rocks , bad clutch pack suspected i dont have pressure specs good luck
  • Posted 28 Mar 2020 01:50
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
Libiao Robotics
