Weak Transmission Pressure
We have a Toyota 02-5FG30 with a 2-speed transmission.
Transmission works but very low pressure & almost will not move in both F/R & or H/L range.
Tested the pump pressure & was very low. Oil is clean & found no debris in oil. Sent out the pump & convertor but came back no problem there. Removed the top valve body & inspected but found no visual problems. Anyone ever ran across this issue.
  • Posted 13 Mar 2020 01:23
  • By JAKE2
  • joined 7 Jul'17 - 36 messages
Check suction filter on transmission.
Make sure inching spool is returning all the way back in.
  • Posted 14 Mar 2020 22:43
  • By James_Lott
  • joined 28 Feb'20 - 9 messages
Sue Tomic Sue Tomic
