Battery won’t charge- can I plug direct
Hello,
My batteries don't seem to hold a charge. I have tried charging for long periods and I have checked the water in the batteries. Is it possible to directly plug my battery charger into the forklift and run it? The plug looks like it would fit but I don't know if it would work.
Thanks
  • Posted 19 Dec 2019 04:08
  • By Bill_Cosden
  • joined 18 Dec'19 - 2 messages
  • Maryland, United States
Hi,
You can't run the truck directly from the charger.
You will need a voltage in the battery to get the charger to work.
Hope this is of some help.
  • Posted 27 Jan 2020 19:55
  • By ForkinAlice
  • joined 27 Jan'20 - 3 messages
  • Northern Territory, Australia
are you trying to running it with the charger instead of the battery? is that what you are asking?
  • Posted 2 Jan 2020 22:07
  • By Mechanic_1217
  • joined 31 May'19 - 9 messages
