No throttle or drive.
Hi this linde is a 350 series gas truck. Not my field however was asked to plug into it with pathfinder and read out codes. From what I understand had light wiring rubbing through and shorting on the chassis.
Plugged in cleared existing codes. Restart the truck, calibrate the foot pedal. In test footpedal value changes when activating foot pedal but engine will not rev. Their is a negative permanent to the throttle actuator but not switching positive which comes out the ecu.
Not sure if ECU is faulty as its not showing any errors. Has anyone had a similar problem?
Thanks in advance.
  • Posted 14 Dec 2019 12:05
  • By elektrodrive
enquiries@elektrodrive.co.uk
Any active codes showing in pathfinder when truck running?? Also plugged into the engine using impco software is it showing any codes??
  • Posted 21 Dec 2019 11:10
  • Modified 21 Dec 2019 11:13 by poster
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Taylor TX175
New - Sale & Hire
Manitou M50-4
Michel Denis Michel Denis
