E16 1991 forklift
I have a problem with the E16 1991 forklift it doesn't have much power/speed when going up a slop
Battery seems to keep its charge ok is there a limiter on the motor or a speed change I can do?
Many thanks
  • Posted 28 Oct 2019 19:52
  • By Craig_Ophide
  • joined 28 Oct'19 - 3 messages
  • Staffordshire, United Kingdom
Showing items 1 - 20 of 23 results.
I have done it
  • Posted 9 Jun 2022 23:06
  • By chronio
  • joined 9 Aug'13 - 37 messages
  • EPIRUS, Greece
CITIUS ALTIUS FORTIUS
Thanks alot all of you. Finally it was wire breakage from the potentiometer. With the wiring draw I found it. Thanks again friends
  • Posted 9 Jun 2022 23:05
  • By chronio
  • EPIRUS, Greece
Hi
Silly question
But have I jacked it up and made sure both motors are working?
  • Posted 9 Jun 2022 19:56
  • By Lindetechnz
  • joined 28 Apr'21 - 58 messages
  • New Zealand
Lindetechnz
I will check and report.
  • Posted 1 Jun 2022 22:32
  • By chronio
  • EPIRUS, Greece
Supply voltage for speed sensors
+ 15 V via 1X13:39
Negative via 1X13:41
SPEED SENSOR IN THE TRACTION MOTOR
The trucks are provided with speed sensor 1B2 as standard equipment. This sensor is mounted on the
flange of the right-hand traction motor.
The speed sensor is powered with 15 VDC. The sensor provides a square wave signal to terminal
1X13:36, over which the motor speed is sensed.
  • Posted 1 Jun 2022 22:11
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
Thanks for all, it's 324. How can I check speed sensor? Remember points of measure for temp sensor? And how many ohm is ok?
  • Posted 29 May 2022 23:05
  • By chronio
  • EPIRUS, Greece
Ok. It is a E16 right? Is it a 324 or 335?
Check accelerator. When it is not in neutral in the first seconds after starting up you have slow drive. Try push and lift the pedal a little bit directly after start up.
Might also be the speed sensor, that is on brake disc of the right motor.
On a 324 the temp sensor might not give a light. This year linde trucks don't have error message on the display too. The temp sensors are variable resistors. Not temp switches.
  • Posted 29 May 2022 18:46
  • By frits_f
2001 definitely no hand brake checked. Temperature sensor may not no lamp of error. Any other idea , thanks
  • Posted 28 May 2022 07:45
  • By chronio
  • EPIRUS, Greece
Chronio, what year and model is your forklift truck?
Often low amps / low speed mean brake switch or handbrake switch is applied. Or the controller thinks it is.
Could also be temperature sensor in drive motor.
  • Posted 28 May 2022 04:47
  • By frits_f
1. When we are on flat surface with full pedal about 70Amps with 48V
2.When on slope full pedal ,can't reach the slope 90Amps if turn the wheel one motor take 200Amps and kicking to reach the slope
3.Some times claping the contactors when depress the acceleration pedal and repress it full the vehicle not moves and have 20Amps to the motor.
Hope to have a good idea.
  • Posted 26 May 2022 17:32
  • By chronio
  • EPIRUS, Greece
Tomorrow I will meter and I will send you.
  • Posted 22 May 2022 21:05
  • By chronio
  • EPIRUS, Greece
and hou menny volts to motor ???
ant ampers?
  • Posted 22 May 2022 21:03
  • Modified 22 May 2022 21:04 by poster
  • By michel_v
  • noord holland, Netherlands
48V count it with digital multimeter. I don't have linde laptop.
  • Posted 22 May 2022 19:43
  • By chronio
  • EPIRUS, Greece
how is your battery voltage under load
accelerator potentiometer
the easiest way is to hang a laptop on it
  • Posted 22 May 2022 18:34
  • By michel_v
Do you have any idea why I don't have torque on the wheels ? The machine in air have full speed but with wheels on the ground can't reach even little slope?
  • Posted 22 May 2022 18:08
  • By chronio
  • EPIRUS, Greece
About 4months ago.
  • Posted 22 May 2022 18:02
  • By chronio
  • EPIRUS, Greece
when you lift the truck, both engines drive at the same speed????
  • Posted 22 May 2022 18:00
  • By michel_v
normaly not
  • Posted 22 May 2022 17:52
  • By michel_v
Can the setting change because a lot of time with out battery? About 4 to 5 months.
  • Posted 22 May 2022 15:29
  • By chronio
  • EPIRUS, Greece
with a linde laptop you can see if it is set to full power
  • Posted 22 May 2022 13:22
  • By michel_v
Unicarriers FD80-2
Toyota 8FG25
