Clark starting problems.
Model is a GCX25E TYPE LP. When trying to start it sounds like the starter just spins. Motor does not turn. Basically sounds like a motor running when key is turned. Possibly a starter?
  • Posted 27 Aug 2008 10:36
  • By Cesar333
  • joined 3 Oct'06 - 9 messages
  • Connecticut, United States
yup ya need a starter but check the ring gear to inspect teeth because if teeth are bad it will chew up the new starter
  • Posted 4 Sep 2008 19:11
  • By dantheman
  • joined 4 Sep'08 - 18 messages
  • New Hampshire, United States
he probably wiped out the pinion clutch in the starter
disconnect battery starting with the negative cable (when youre done connect the negative last)
when you take the starter out inspect the ring gear for damage
if it sounds like its not engaging anything (no grinding) the ring gear would have major visible damage
when you have the starter out in your hand try to spin the little gear
if it spins easily in both directions the clutch is wiped out
if it is good there should be stiff resistance when you try to spin it one of the directions
the throw out fork could be bad too
either way take it to the local starter/alternator shop and have them bench test it (yellow pages - automotive electric)
they can also tell by looking at the pinion what other issues you may have
also you might want to take digital pics of the ring gear to bring down to show them
  • Posted 28 Aug 2008 11:26
  • Modified 28 Aug 2008 11:28 by poster
  • By justinm
and or ring gear. be sure to make sure the key switch is the sort that only turns to the start position after turning all the way off. and or change the key switch when you change the starter and ring gear.
  • Posted 27 Aug 2008 20:40
edition #1257 - 20 November 2025
