Very slow forward and reverse no codes
I have a 2003 h20t propane machine that all of a sudden has no speed in forward or reverse the machine starts fine ,lift works fine and steering works fine no codes. It will move very slow either direction seems goes slower yet when engine revs. Anyone seen this or have any ideas.
  • Posted 12 Aug 2019 13:51
  • By David_Minzey
  • joined 12 Aug'19 - 3 messages
  • Michigan, United States
Always learning
Do you think it would be immediate though it was working fine then immediately did this the center brake valve sounds like alot of fluid flowing through it. I wont be taking to a linde dealer i will fix myself already removed entire wire harness and repared when i got the machine so im capable just looking for someone that might have had similar issue.Thanks
  • Posted 18 Aug 2019 01:02
  • By David_Minzey
Always learning
The correct serial # is H2X350R02754. The only way to troubleshoot it is by doing hydraulic pressure checks which should be done by a Linde dealer. My guess is that the hydraulic drive motor is worn and if so it wouldn't be worth repairing the truck with so many hours on it.
  • Posted 17 Aug 2019 21:56
  • By duodeluxe
  • United States
duodeluxe
The serial number tag has had something rake across the lh side of it but this is what i can make out.
Hilo serial number 2x35qr02754 model h20ct-600-03 15150 hrs on meter. Any help appreciated
  • Posted 15 Aug 2019 10:58
  • By David_Minzey
Always learning
Please post serial # and number of hours on meter.
  • Posted 13 Aug 2019 21:25
  • By duodeluxe
  • United States
duodeluxe
Hoist Liftruck P360-48
Taylor TT300
Michel Denis Michel Denis
Taylor TT300
