starts low idle then dies impco100
checked and found no fuel pressure changed lockoff and vaporizer
while i had air cleaner off i tuned it up ( cap rotor wires plugs module )
fired up ran great was checking temp and for leaks , then died started doing same thing started idle low dies , changed carb still same , drained fuel system truck will run great with gas rag over carb truck has 155 compression on all four
  • Posted 7 Aug 2019 11:32
  • By owen_r
  • joined 19 Jul'12 - 12 messages
  • Kentucky, United States
O
I missed that you changed the carb. If you have a vacuum gauge, check the vacuum while cranking. If you get large pulses this can cause the system to not prime properly. some times a valve adjustment will help
  • Posted 8 Aug 2019 07:06
  • By BREWSKI
Which carb/mixer does it have on it? If it is a CA100 check the diaphragm.
  • Posted 8 Aug 2019 07:03
  • By BREWSKI
It has a new lockoff that's the only filter and I have fuel through the lockoff to the vaperizer
  • Posted 8 Aug 2019 01:04
  • By owen_r
O
Check the in line fuel filter. Also check your LP coupler.
  • Posted 7 Aug 2019 22:16
  • By BREWSKI
