Display access
This unit is a AG1N1L20V. Need to know how to access the display. Tried holding down 1 and 3 while turning the key switch on. Also, 1 and 4. The only thing I can get the display to do is go blank while trying those keys.
  • Posted 20 Jul 2019 04:50
  • By roadkill
  • joined 20 Jul'19 - 2 messages
hello mr zygmunt_s,
i do not have as much info on these units as Yidneck does.
you may want to try and contact him, he may have what you're looking for.
As far as trying to contact me? your emails must have been going to my spam box, usually i may scan through it but i get alot of spam so i may have deleted them by accident, sorry about that sir :o).
  • Posted 28 Sep 2023 01:58
Hello swoop223,
Do you know how to change tilt angle sensor settings in Unicarriers 1N1 series electric truck?
Been trying to contact you by email but not sure you've received them...?
Thanks in advance.
  • Posted 28 Sep 2023 01:28
  • By zygmunt_s
  • joined 22 Oct'08 - 47 messages
  • Zachodniopomorskie, Poland
2022. Your post still helping people. Thank you
  • Posted 1 Jun 2022 01:50
  • By Techman
  • joined 29 Jul'15 - 22 messages
  • Michigan, United States
I make them pick things up, and I make them put things down, and I make them drive around.
Thank you
  • Posted 22 Jul 2019 22:32
  • By roadkill
For diagnostic mode press 1 and 4 while turning key when you get blank screen press 2341.
For adjustment mode press 1 and 3 and then 3123.
  • Posted 21 Jul 2019 15:36
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
there is not one single code to use to access changing settings on these trucks, there are several codes to enter to unlock or lock a function and change settings, each unlock code is unique to what you want to unlock and then there is another code or set of codes used to actually change the range in that particular setting you want to change.
What exactly are you looking to change?
  • Posted 21 Jul 2019 00:24
