Hyster K0.6M
Hi,
I have one problem with order picker Hyster model k0.6m year 2005.
It works for a little and then it stops, but it just stops when i want it to reverse.
I have checked the engine and all of the electrical linkings are ok.
What may be causing this problem?
thanks
  • Posted 18 Aug 2008 02:32
  • By rafael
  • joined 18 Aug'08 - 30 messages
  • oliveira de azemeis, Portugal
quality ahem (raised eyebrow). i know exactly what you mean. i have 3 c1.3 dc trucks on a site. 1 of them never ever gives any probs second truck behaves itself quite well but the third one is always giving me headaches.
  • Posted 3 Oct 2008 09:09
  • By kevin_k
hello kev.hand set said Qline sensor ko.turned out to be a broken wire in one of the flat cables going over the mast.when you looked closley at the cable you could see a bubble in it where the wire had bunched up inside.luckily theres a few spares in those cables so an easy fix.quality product those k1's
  • Posted 2 Oct 2008 06:36
  • Modified 2 Oct 2008 06:37 by poster
  • By tugmaster
  • joined 25 Aug'08 - 73 messages
  • United Kingdom
don,t tell me. feedback pot failure
  • Posted 2 Oct 2008 03:48
  • By kevin_k
did this problem get solved?i just had a k1.0 with similar probs and it was a steering fault
  • Posted 1 Oct 2008 04:01
  • By tugmaster
  • United Kingdom
the controller must have a LED to indicate a fault. what controller is it? H1, H2. COMBI?
  • Posted 1 Oct 2008 01:30
  • By silvio
  • joined 30 Sep'08 - 29 messages
  • buenos aires, Argentina
EMAIL silvio_jorge@hotmaildotcom
you need to get a zapi handset and plug it into controller to diagnose fault. or it could just be the throttle assy
  • Posted 21 Aug 2008 06:13
  • By kevin_k
