WIRE GUIDANCE
I recently came across a major defect in zapi wire guidance systems..... as with the older keltronic systems when the loop is broken no guidance ,,,,,,,,, But with zapi half the warehouse will work...... not the best situation i would think....... My question is ,is there a way of adjusting the smart antennas so they are less sensative... cheers damo
  • Posted 17 Aug 2008 22:01
  • By DAMO
  • joined 9 Jan'07 - 196 messages
  • DUBLIN, Ireland
ONLY ONE LOOP KEVIN......ONE LINE DRIVER ON THE WALL I EVEN DISCONECTED ONE OF THE WIRES FROM THE DRIVER....... THE MACHINE WILL DRIVE UP TO 150 METERS ????????does not add up
  • Posted 22 Aug 2008 01:51
  • By DAMO
  • DUBLIN, Ireland
damo ,you must have 2 loops in your floor. zapi will guide if there is a signal
  • Posted 19 Aug 2008 03:41
  • By kevin_k
