Lift Motor Keeps Running
I have a Raymond Pallet model 8410. The problem is jack with go up. Then stay there. Will not come down and the lift motor with keep running. Disconnect the motor. But the lift truck stays in the up position.
  • Posted 5 May 2019 21:35
  • By kdman95
  • joined 5 May'19 - 3 messages
  • New Jersey, United States
Thanks will try and let you know..
  • Posted 6 May 2019 23:39
  • By kdman95
check for a stuck contactor/solenoid
it will not lower if the motor is running and if you disconnect the battery it cannot lower because the lowering solenoid cannot work with no power.
you can disconnect one of the power cables at the hydraulic motor and pull one of the leads off the solenoid/contactor coil and then the lowering circuit may work to allow you to lower it.
  • Posted 6 May 2019 15:34
edition #1235 - 19 June 2025
Hoist Liftruck F180-36BOX-CAR
UN Forklift FD35T
Kalmar DCG16-900
Terberg YT222
