Reach stacker starting problem
Hello,
I have a Reach stacker which I have bought 2008 from Konecranes. Last 4 months we could not start the machine. It means when I start the machine first time in a day, I can start it and operate in around 2 hours. if I stop the machine meanwhile, then I could not start it. But if I wait for a while suppose 30 min, then I could start it. The engine running hour is now more than 20000. It is mention that, we have done only engine Top overhauling and tried with different recondition self starter. Do you have any idea ?
Thank you
  • Posted 1 May 2019 20:41
  • Modified 1 May 2019 20:42 by poster
  • By mostafa_raju
  • joined 1 May'19 - 2 messages
  • Bangladesh
See the all line of fuel and chek the rev sensors because ecu dont open the line of fuel
  • Posted 21 Jan 2024 08:51
  • Modified 22 Jan 2024 04:53 by poster
  • By Gledis_Adilaj
  • joined 21 Jan'24 - 1 message
  • Albania
Hello i have the same problem with stacker engine kumins dont start
When we start for 2nd time, for few seconds we hear the cranking sound. But the sound is not proper one as we hear from normal cranking. And the cell (self starter) burns. it happened 5 times. We have two battery of 12 volts.
  • Posted 2 May 2019 16:11
  • By mostafa_raju
  • Bangladesh
can you start and not happens or start with cranking engine but not running?
  • Posted 2 May 2019 05:27
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Kai von Berg Kai von Berg
Lift Tek Elecar
