hydraulics Drift
All three hydraulic functions drift after releasing the finger controls. We didn't have this problem until we reset some of the perimeters on the forklift. Is there a setting that would make the hydraulics drift?
  • Posted 24 Apr 2019 04:02
  • By albuq
  • joined 24 Apr'19 - 3 messages
  • New Mexico, United States
That can happen. You can do a reset defaults and this will reset to factory presets.
  • Posted 25 Apr 2019 22:23
  • By BREWSKI
Brewski
Thank you for the info. It did calibrate the valves but the drifting was in the setting on the lift lower ramp. I had it set at 1 and changed it to 10 this stopped the drifting. Thanks again
  • Posted 25 Apr 2019 07:13
  • By albuq
Once you select the function, you move the minilever until the function starts to move then hit the * button. Do the next function the same way. Once you have them all done, scroll until you see exit and save.
  • Posted 24 Apr 2019 22:43
  • By BREWSKI
We do. I tried to calibrate them but I couldn't get it take the calibration. Didn't really understand the (press star at creep. Can you maybe explain that a little better.
  • Posted 24 Apr 2019 07:09
  • By albuq
You need to calibrate the levers. Do you have access to the dash service level password?
  • Posted 24 Apr 2019 07:05
  • By BREWSKI
Elwell-Parker ESI500-36
Taylor TT300
