No Movement Forward or Reverse
We have a lift that, after hitting a bump, will not move forward or in reverse. If you unplug the battery and plug it back in, you can attempt to move in either direction, and all that happens is a spark and a jolt in either direction, but nothing to follow. It will move up and down. Any suggestions?
  • Posted 26 Mar 2019 02:29
  • By benjammin
  • joined 26 Mar'19 - 1 message
  • Kansas, United States
~Am I missing an eyebrow?~
I don't know if this is an old post but by the model looks to maybe have and old ev100 system in it by the way it sounds it could have shorted out the 1 rec need to check the rec look at 2 and 5 also hope this helps
  • Posted 23 Jan 2022 09:20
  • By Scott_
Scott
Your hyd leak has nothing to do with your travel issue. Can you hear the contactors pull in when you turn the throttle?
  • Posted 20 Jan 2022 13:43
  • Modified 20 Jan 2022 13:43 by poster
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Did you have any luck with this situation? Ours has currently started doing this same thing but we also have a hydro leak on the lift mast. I'm wondering if low fluid levels could cause the drive not to function. Might not be the same diagnosis on yours.
  • Posted 21 Dec 2021 01:21
  • By Joseph_Brockman
  • joined 21 Dec'21 - 1 message
JBrockman
UN Forklift FGL18T
Crown WP302020
