No forwards or Backwards movement - Fault Code FE-1
Hi - our stuck has stopped moving backwards and forwards. Everything else works. We have the fault code FE-1 showing on the panel. An engineer has come to have a look and thinks it could be the SCPU or CPU controllers. Would anyone know if that is correct and where we could have them looked at in the UK. The engineer wanted to just buy a new one to test for £3000+ which is crazy money. Any help would be much appreciated.
Many thanks
  • Posted 9 Mar 2019 09:28
  • By James78
  • joined 9 Mar'19 - 1 message
  • United Kingdom
If the toyota numbers on the controllers are the same, then you can exchange them.
Also you can exchange drive and pump controller to see if problem then occurs to pump.
  • Posted 1 Nov 2023 08:47
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
How can i trace which one is bad?
I have another 7bfmf from another year, that i am thinking to switch the main controller to see what is the status.
Do you think i risk damaging the controller ?
  • Posted 31 Oct 2023 16:03
  • By BogdanHurezeanu
  • joined 31 Oct'23 - 1 message
  • Romania
SAS controller, main controller communication error.
  • Posted 10 Mar 2019 22:33
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
