Diagnozer
What cable do you use to connect Diagnozer to Cat lifts? The cables I see have a 9pin 2-row plug opposite machine end. Where do you plug this in? Do you need a separate com-link to plug this cable into and then into laptop? Machine also has a round cat-9pin diag connector- same as heavy equip. I have a cat-com 3 that will connect to lift but Diagnozer wont communicate with it. Should I be able to? If not, why does it have it?? FYI This is a diesel lift. Thanks
  • Posted 12 Feb 2019 06:49
  • Modified 12 Feb 2019 07:34 by poster
  • By JayR
  • joined 10 Nov'15 - 38 messages
CAT Lifts Diagnostic Cables Part numbers
16A68-11420
16A68 -11320
16A68 -00500
16A68-00800
These cables require the software (Up-time for Mitsubishi and Diagnozer for CAT or TruckTool) to work with.
  • Posted 10 Aug 2025 20:35
  • By Dil_Era
  • joined 30 Jun'25 - 37 messages
dilshanrandeep@gmail.com
well that sounds like the cable diagnozer uses.
a square rectangle'ish plug with 2 rows of pins, the connector has some special ridges that allow only it to fit in the female connector on the truck harness. The end that connects to the pc side is a db9 serial and with today's computers you will need a usb to serial adapter. The newer cables they have may have a usb connector on the pc end now but the older cables had db9 serial.
You can only obtain these cables from caterpillar officially. An aftermarket solution MAY be available but i wouldn't hold my breath on that, they are not in the practice in letting their proprietary software or hardware out, it is dealership specific and only given to trained technicians and the software is tagged to the computer service tag it is installed on.
  • Posted 12 Feb 2019 12:18
  • Modified 12 Feb 2019 12:18 by poster
Toyota 02-2TD20
Mitsubishi Logisnext FD25T5M
