Going slow.
So I have a Big Joe E-30 and it moves forward and back very slowly. it's acting like a bad battery or almost dead. I checked the battery voltage and it's a little over 12 volts each or just over 24 volts together. It lifts and goes back down normally. The Red light on it is solid. No flashes.
I don't know if it's some safety switch in the handle flaking out or something. I do have to say it's been pretty unreliable. It's not all that old either. A couple of years. Have had to replace these expensive batteries once before. Any ideas?
  • Posted 10 Jan 2019 10:37
  • By JBDragon
  • joined 23 Aug'18 - 15 messages
hey prentice,
First off make sure the batteries are fully charged or have enough charge to run the truck.
you probably want to get your hands on a curtis handset or if you can get hold of "PC programmer" for use with a laptop and plug into the controller and see whats going on, the problem could be either the tiller control or a setting in the controller. Also could be the brake dragging, when you energize the truck do you hear the brake release?
Plus after looking in the operators book it does suggest that there are 2 different modes this control can be programmed which provide 2 sets of speeds it can operate at. It does not say they are switchable from the control handle so i believe this is something that has to be done with the handset.
I would pay attention closely to the control handle, these aren't the best in the world and i've had issues with these they use with this controller in the past and they do break in various ways that cause problems in the truck operation.
  • Posted 26 Apr 2019 21:21
  • Modified 26 Apr 2019 21:23 by poster
Hello Swoop,
Can you send me an email
prenticelift @ gmail dot com
I am having an issues ( Slow Drive )with a 2017 eps-22 Blue giant ( BigJoe)
  • Posted 26 Apr 2019 02:11
  • By Prentice
i know it's been a week or so since you posted this so i'm just replying to see if you figured it out yet.
Going on you saying the machine may only be a year or two old based on what i find in the E30 service literature on bigliftsupport website this unit most likely has the curtis control system in it?
Has a BDI indicator along with an LED lamp?
I'd be curious to what the BDI level is showing, fully charged, discharged (yellow or red blinking led's on the scale)?. Is it showing any error codes before or during operation?
As for checking the batteries in general if they are fully charged you should be getting higher than 24v (12v on single battery).
You should be reading about 13.5 on a fully charged battery (25v to 27v on both together).
I would put the unit on the charger and test to make sure it is even charging, make sure the charger cycles through it's test when first turned on(if it has an analog needle indicator then it should show amp rate level), then with a multimeter hooked to the battery watch the voltage when the charger actually kicks into charge mode and see if the voltage increases, you should see a significant increase during charging with it gradually increasing. The charge voltage may even exceed the fully charged volts during the finishing charge time but as the battery cools down when the charger shuts off the voltage will level off and should settle at what the actual voltage is after charging. (around 25.5 to 27v).
Another thing to do is after charging run a volt drop test on the batteries, use the multimeter and hook across the batteries, note the voltage. Then operate the hydraulics, let it raise the forks to full height and stall the hydraulic pump, hold it there for about 15 secs and see what the voltage drops to. With a good condition battery it should not drop more than 1 to 1.5v, if you get a drop more than that you most likely have a spent battery or defective cell(s).
Then there is always the controller settings, using a curtis handset or pc service tool checking and making sure the factory settings are set correctly so that the highspeed is not inhibited by an incorrect setting. The service book has all the factory settings listed and can be easily checked.
But after all this being said i would lean towards it being a battery charge issue from your description.
  • Posted 27 Jan 2019 01:18
  • Modified 27 Jan 2019 01:21 by poster
Terberg YT220
Crown CG33P5
Sue Tomic Sue Tomic
