no travel, code 46, blowing FU1
Hi Fellows,
this unit is blowing fuse 1 , 300A.
with a good fuse the F/R contactor close but it drop open inmidiatly, then displays 46 for a second.
any help is appreciated.
can someone give me acopy ot the wiring diagram?
Thanks.
  • Posted 24 Oct 2018 13:46
  • By MipTexas
  • joined 10 Jan'18 - 3 messages
MiP
Hi MiP
actually the REC's are not like on the older systems
there is one large square one underneath the spider block assy, this is the #1 REC, then beside that are 2 smaller ones which are the #2 and #5 REC's.
Those silver diodes with pigtails you see are the #3 and #4 REC's.
If you want a panel schematic you can go to flight systems website and lookup the GE EV100LX manuals and they have all the information you need to identify and check these parts.
www. fsip. biz (remove the spaces i added to this url to make it work, or you can google fsip.biz and it should come up as the first hit. Go to the support pages and you can find technical manuals there for that panel.
  • Posted 25 Oct 2018 14:31
  • Modified 25 Oct 2018 14:32 by poster
Hi ,
Thanks for the info.
REC's are the big silver tail diodes, right?
I did check all 3 tested good.
Contactor was burnt , cleaned it and looks good now.
If you can provide me with a electrical schematic, it
will help me a lot.
How can I test the motor. ?
Thank you again.
  • Posted 25 Oct 2018 00:41
  • By MipTexas
MiP
status code -46
Look ahead test for T2 volts. (greater than 85% of battery volts)
symptom: fwd/rev contactor will not pick up
possible cause:
-check for shorted 1REC
- check for defective 1REC insulator that may short 1REC heatsink to base plate.
-Defective 1A contactor power tips
check the 1A contactor and make sure the tips are not welded together.
then check the drive motor and cables, make sure there are no shorts, then of course check the 1REC.
  • Posted 24 Oct 2018 21:37
Rail King RK330
Hangcha FLDCXT160
Rail King RK330
Hangcha FLDCXT160
Libiao Robotics
