SJ3226 won't move backward
Hey guys,
I got an SJ3226 and the operator complained that the lift stop going backward all of a sudden.
Now it doesn't even respond to the command of the joystick when going back, but when going forward the equipement doesn't move, but you can hear the hydraulic unit going. The pins on the wheel doesn't go back in to allow it to move. Could it be a solenoid?
And if you have any ideas for the backward issue, would be greatly appreciated.
  • Posted 7 Sep 2018 03:56
  • By michel_d
  • joined 30 Jun'18 - 30 messages
  • Quebec, Canada
Ty to take the joystick unit and plug it straight in the back of the skyjack where the ladder is. If it works fine you know your problem is in your harness between the base and the top cage.
  • Posted 23 Nov 2019 06:11
  • By michel_d
  • Quebec, Canada
No the pump doesn't run. It will move a little then just stop
  • Posted 23 Nov 2019 06:06
  • By ChiliMan
  • joined 23 Nov'19 - 2 messages
  • Wisconsin, United States
Ryan
Does the pump run when you activate the joystick?
  • Posted 23 Nov 2019 06:01
  • By michel_d
  • Quebec, Canada
Do you remember hoe you fixed the reverse problem?
  • Posted 23 Nov 2019 05:44
  • By ChiliMan
Ryan
Not that I remember. It sounds like the seal is bypassing in the cylinder.
  • Posted 17 Sep 2018 22:44
  • By BREWSKI
Would there be any kind of safety valve or something that would prevent it from releasing the brakes?
  • Posted 17 Sep 2018 21:46
  • By michel_d
  • Quebec, Canada
Just checked it and yes I do have oil going through the hose to the cylinder.
  • Posted 7 Sep 2018 23:03
  • By michel_d
  • Quebec, Canada
Could be a stuck valve or a blown seal in the brake cylinder. Have you checked to see if there is oil delivery at the brake cylinder?
  • Posted 7 Sep 2018 22:22
  • By BREWSKI
Solved the issue with the no backward problem, now it's just the brakes that won't let go.
Checked the relays they all seem fine, I've got power going in and out of the solenoids. Could it be the valve that isn't working properly?
  • Posted 7 Sep 2018 05:54
  • By michel_d
  • Quebec, Canada
If this could give any hint, while playing with the control box, when I pressed the horn button the hydraulic unit started?
  • Posted 7 Sep 2018 04:49
  • By michel_d
  • Quebec, Canada
Sue Tomic Sue Tomic
VETTER Forks, Inc.
