H50D hydraulics slow down after machine is up to temp
I have a H50D that the lift and tilt slow down after it heats up intermittently.
Serial H2X394A00401 Engine is CBJB
side shift and the fork positioner do not seem to be any different.
I checked with pathfinder to make sure that the lift and tilt are set to 100% for the speeds.
The engine still revs up like it should when moving the levers.
The engine has been replaced recently. I have also replaced the two valves that are on the end of the hydro static transmission. The issue did not change with the valves.
Is there a priority valve that we are missing or could it be a worn out pump?
Anyone have any information on this issue?
Thank you in advance
  • Posted 11 Aug 2018 06:20
  • By Jshua
  • joined 19 Jan'16 - 7 messages
Unfortunatley we did not. Dealers in the area could not either so new forklifts from other manufacturers were purchased.
  • Posted 9 Apr 2019 23:53
  • By Jshua
hi have you found your problem?
  • Posted 25 Mar 2019 07:51
  • By nike_w
  • joined 25 Mar'19 - 1 message
  • Sweden
Michel Denis Michel Denis
