Stuck in Manual mode
We have a crown SP3020-30 that was having problems with the display module. You would turn the key and just 2 little green lights would come on the board no POST beep. We replaced the display module with 1 we found on the internet. It now turns on beeps a single time for POST, but it says manual and has the service wrench lit up. We still have the ability to raise and lower the unit but we can't drive or turn the unit. If you start it up with your foot on the deadman switch you will hear the break disengage but immediately reengage. If you start it without the switch engaged it will not even try to disengage. I can't seem to figure out how to find any error codes as all it does is show me the manual message. If I click the information button I get info that says c1 - 423 and it counts up to c15 - 423. From looking at an incomplete service manual that says its a problem with the guidance system. We don't have a wire guidance system on this orderpicker and never did.
Now we replaced the display module with a new 1 but the only difference was after the serial number on the original is say Rev G which the new 1 doesn't and I couldn't find 1 that did. Any thoughts?
  • Posted 28 Jul 2018 00:20
  • By h4mm3r0g0d
  • joined 27 Jul'18 - 1 message
  • United States
I'm having the exact same issue maybe I posted in the wrong place I used my service terminal To make sure that Showed no wire guidance and no manual mode Both are disabled But I'm still having this error code And I'm not really sure what to do with it Um Could it be in the distribution card? Any help would be greatly appreciated
  • Posted 10 Apr 2024 01:15
  • By erik_hagelberg
  • joined 8 Apr'24 - 7 messages
  • Tennessee, United States
hi, i'm having the same issue but i HAVE a service terminal.. i programmed it not for wire guidance or manual mode. is this a display issue? it wouldnt have anything to do with the GE-EV system would it? thanks for your help!
  • Posted 8 Apr 2024 22:04
  • By erik_hagelberg
423 is a guidance module not connected code. You mentioned you do not have guidance... Sounds like the settings in the truck thinks it does and cannot communicate with it. Like mentioned in previous response. You need a service terminal to check and correct your settings. Without the service terminal you are shooting in the dark and cannot change/correct any settings. When you buy modules (specially used) you never know what options are turned off or on. They always have to be set up to your specific options on your truck. If you have removed options, the controllers have to have the option turned off with the terminal or the display will throw fault codes and in most cases lock the truck down.
  • Posted 4 Aug 2018 07:12
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
First thing you will need is handset to plug in under the accelerator grip to turn off wire guide and any thing else that the truck this came off of had your does not.
  • Posted 29 Jul 2018 20:51
  • By popeye
