Unit will not move
Hydraulics in the front work lift works great no motion on the unit no forward no reverse
  • Posted 10 Jun 2018 16:08
  • By Snuffy
  • joined 10 Jun'18 - 4 messages
Pretty tough to diagnose without a fault displayed. Check to see that the start switch in the accelerator pedal is not closed before key on. Also check to see that one of the directional switches is closed before key on. These things will cause a no travel fault on start up. It may have a bad start switch in the accelerator control. A handset would be helpful to diagnose this problem.
  • Posted 22 Jun 2018 22:17
  • By BREWSKI
I'm not sure which control system it has. The idiot lights display has the parking brake brake pad warning light and Manuel. You has a code 0399. if I knew the codes that might help a bunch. Maybe this information will help you help me I do appreciate your response and together maybe we can figure this out thank you, Snuffy.......
  • Posted 22 Jun 2018 17:50
  • By Snuffy
Does this have the EV100 control system? What is the display showing? You are not giving us much to go on. What have you checked so far?
  • Posted 11 Jun 2018 22:26
  • By BREWSKI
Really can you know one out there help me?
  • Posted 11 Jun 2018 19:52
  • By Snuffy
  • Posted 11 Jun 2018 19:51
  • By Snuffy
Esie Cortez Esie Cortez
Oxford Ct, United States
