Code 5D
I am working on a Raymond EASIR4TT Reach truck. The truck doesn`t do anything and displys a code 5D. Can anyone please help me? What is that code for?
  • Posted 19 Jun 2008 06:19
  • By forkliftbob
  • joined 28 Aug'05 - 4 messages
  • Michigan, United States
ok here is my follow up. had to call local RAYMOND dealer to check out code 5D. according to them my model truck should not show that code. i believe it had to do with my truck not having "SMARTI SYSTEM" but the tech did not confirm that. however, he cleared the original software on the VFC and re-installed proper version of software and code is now gone. truck is now operational.
  • Posted 27 Oct 2017 07:14
  • By glenn_levit7
  • joined 10 Jul'07 - 78 messages
Montacargas, Tequila y Limon!
hello, i have an R40TT truck with a 2E and 5D showing on display. 2D refers to 2e - traction motor temperature out of range and after reading your posts i have a better idea what code 5D is. is this common? to have multiple error codes displayed? also which error code should i troubleshoot first?
regards
Jay
UPDATE: 05/11/2017
took care of 2E issue. had VFC tested at FSIP and tested good. truck turns on, completes self test, then displays 5D. all hydraulic functions work. however, i'm limited to 1mph on FWD/REV. i don't see a cable from the VFC to Smarti and i tried about 20 different variations of password and can't access config menu. looking for help..willing to trade.
regards
jay
  • Posted 12 May 2017 06:25
  • By glenn_levit7
We are getting a code 5d. The model is easi dr30tt, serial is ez-a-o2-24665. any thoughts
  • Posted 26 Jan 2011 01:09
  • By sal_u
  • joined 26 Jan'11 - 1 message
  • New Jersey, United States
even if it has SMARTi unplug JPS9 and shut it off in the program
just to get it running
  • Posted 22 Jun 2008 10:56
  • Modified 22 Jun 2008 10:57 by poster
  • By justinm
Chances are SMARTi is enabled go into the config menu & turn it off.
  • Posted 20 Jun 2008 13:20
  • By pappy_f
  • joined 20 Apr'07 - 16 messages
itd help to have the serial number
but according to the book i have:
code 5D
no SMARTi system response
according to this you should have 1 mph speed restriction
check the cable from the system card to SMARTi module
onthe system card its a serial cable just above the fuses on the large card connector JPS9
the connector on the SMARTi module is JR1
other than that it might be a bad SMARTi module or a bad VFC (vehicle function card)
but this info really depends on the serial number
  • Posted 20 Jun 2008 12:54
  • By justinm
Esie Cortez Esie Cortez
Oxford Ct, United States
UN Forklift FBT20NQZ1
Terberg RT223
Terberg RT223
Zhejiang UN Forklift Co., Ltd
