Hyundai 25L-7, hard start/ no idle.
Back story, this unit had a bad converter seal and leaking front pump seal. Removed engine, replaced seals, and re-install engine. Now, I cannot get the unit to idle, as well as hard starting. Will run great when pedal is fully depressed, or anywhere between 1/4 throttle to full throttle, however when pedal is released, unit stalls out. Replaced accelerator pedal (electronic) combed over every inch of engine to make sure I didn't miss anything. Any ideas?? After unhooking battery, and waiting 5 minutes or so, can hook up battery and unit will idle, then stall out when pedal is depressed at any position. Is there a learning procedure?
  • Posted 15 May 2018 03:08
  • By Meegie
  • joined 15 May'18 - 1 message
  • Virginia, United States
I am having this same issue, wondering what the fix is and what the 5 short beeps mean?
  • Posted 23 Jan 2024 12:16
  • By JACE_KIRK
  • joined 23 Jan'24 - 1 message
  • Utah, United States
JaceKirk
Sue Tomic Sue Tomic
