No Reverse
Hi Guys. I just bought a Cat VC60DSA serial#4CC00800. It wont go in reverse. With the park brake on I start it and put it in forward all is fine when I release the brake it goes forward. When I put it in neutral it still wants to go forward. When I put it in reverse its like it locks up, like its trying to go forward and reverse at the same time.
I've checked the wiring to the solenoids, all seems to be right. I don't know if the actual solenoid valve is working , They both click when activated but are they working ? I've pulled the valve body off and all the moving parts seem ok as far as I know. Does anyone here have any Ideas of what it could be ? Any manuals would be appreciated as well. Thanks Gary
  • Posted 22 Dec 2017 16:29
  • By gmweld
  • joined 22 Dec'17 - 8 messages
  • Alberta, Canada
it wouldn't let me send my email but text me at 403-359-3355 and I will send it to you. Thanks
  • Posted 24 Dec 2017 07:28
  • By gmweld
  • Alberta, Canada
[email address removed]
  • Posted 24 Dec 2017 07:26
  • By gmweld
  • Alberta, Canada
The oil in the hyd tank is clean like its new and its clear. dosent smell like gear oil. oil in the diff is the same light brown and it don't smell like 80- 90 either
  • Posted 24 Dec 2017 07:25
  • By gmweld
  • Alberta, Canada
send me your email and i can send you a v50d transaxle manual, should be the same depending on your ser number.
  • Posted 24 Dec 2017 07:23
  • By forktime
  • joined 22 Dec'17 - 31 messages
  • Alberta, Canada
I just bought this in Lethbridge. I think the guy said it came from Med Hat area
  • Posted 24 Dec 2017 07:18
  • By gmweld
  • Alberta, Canada
did you just buy this off kijiji from edmonton area?
  • Posted 24 Dec 2017 07:14
  • By forktime
  • Alberta, Canada
can you tell if its regular gear oil? like 80w90? to me its sounds like the forward clutch pack is siezed. but the front diff should be a drivetrain oil NOT GEAR OIL.
  • Posted 24 Dec 2017 07:13
  • By forktime
  • Alberta, Canada
Is the oil dipstick on top of the rearend the one I should be checking ? That is the only place I can see to check oil.
  • Posted 24 Dec 2017 06:58
  • By gmweld
  • Alberta, Canada
The oil doesn't smell burnt , and the oil looks clean and not red like atf
  • Posted 24 Dec 2017 06:49
  • By gmweld
  • Alberta, Canada
does the oil smell burnt? it should be red atf not brown.
  • Posted 24 Dec 2017 06:37
  • By forktime
  • Alberta, Canada
I'm not sure but I think not. It has two pedals, brake and inching pedal
  • Posted 23 Dec 2017 17:02
  • By gmweld
  • Alberta, Canada
sounds like the forward clutchs are siezed? does this have on of those monotrol pedals?
  • Posted 23 Dec 2017 07:19
  • By forktime
  • Alberta, Canada
