lift won't raise
Every thing else works but it won't raise. I don't hear the contactor closing.
How can I diagnosis the issue.
I daon't have a wiring diagram
  • Posted 15 Dec 2017 08:14
  • By rickmechanical
  • joined 15 Dec'17 - 3 messages
BDI reading?
reason i ask is it could be in lift lockout mode
travel will still operate when in lift lockout
the BDI will either be flashing the last 2 red bars or it will be showing a code depending on which type BDI it has
  • Posted 14 Jan 2018 05:15
  • Modified 14 Jan 2018 05:18 by poster
You will need to contact a local dealer. The diagram is not in PDF format so it will need to be printed locally.
  • Posted 16 Dec 2017 02:38
  • By BREWSKI
Do you know where I can get a wiring diagram?
  • Posted 16 Dec 2017 01:08
  • By rickmechanical
Most of the older Yales are color coded or marked.
  • Posted 16 Dec 2017 00:36
  • By BREWSKI
I checked the MICRO switches and they are good , but how can I follow the wires to where they go, are they marked?
  • Posted 15 Dec 2017 09:57
  • By rickmechanical
Start at the lift switch and work your way back to the contactor.
  • Posted 15 Dec 2017 09:02
  • By BREWSKI
Sue Tomic Sue Tomic
