serial number AT35 00047
Top of the dash has all your fault lamps. Top middle is a exclamation mark that came on and stays on. Hour meter won't display because there is something trying to display but never really gives you an idea what it is. Almost looks like part of a p. Unit runs good but I can get the lamp to flash on and off if I run hydraulic lever into relief and lowers the RPM's. If I lower the RPM's then my hour meter displays a fault code "24". Any idea why lamp is on? Need help!
  • Posted 14 Dec 2017 04:01
  • By easymo
  • joined 20 Oct'17 - 6 messages
  • Michigan, United States
Or code F-24
Attach-1 lever error
  • Posted 14 Dec 2017 05:05
  • By kevin_t
Could be cide E-24..
Accelerator sensor error signal
  • Posted 14 Dec 2017 05:03
  • By kevin_t
Taylor TX330S
USD159,500
Zhejiang UN Forklift Co., Ltd
