Engine dies when in full turn.
I have a Hyster S50XM with a brand new, 3.0 long block GM engine in it. It also got a rebuild on the carb. It is now stalling out whenever it is in a full turn unless the idle is raised quite a bit above spec. The hydraulic pressure is just above 1500psi in a full turn. Not sure what to check next. Any help would be greatly appreciated.
  • Posted 21 Nov 2017 00:22
  • Modified 21 Nov 2017 08:51 by poster
  • By lvscr
  • joined 24 Apr'14 - 41 messages
  • Idaho, United States
**** the ignition timing. Make sure the advance mechanism is retarding @ idle speeds.
  • Posted 21 Nov 2017 13:56
  • By Horse
  • joined 11 Jan'11 - 38 messages
  • Wisconsin, United States
Jeff Bykowski
Sorry about that, it's a S50XM.
  • Posted 21 Nov 2017 08:52
  • By lvscr
What "carb" did you rebuild. These do not have carbs. The Fortis truck does not have a 3.0, they use the GM 2.4.
  • Posted 21 Nov 2017 07:23
  • By BREWSKI
Toyota 02-8FD25
UN Forklift FGL18T
ROYPOW
