C500Y60 Fuel issue
We picked up this lift about 6 months ago, had a new model J regulator and CA100 mixer I put on, it would start and idle okay, but it smelled very rich but needed choked to run anything over idle, if you didn't choke it and gave it throttle it would just fall on its face and die. Even running choked the engine didn't have much power, it is a f245 continental. since then it has new LP hoses and I installed another mixer and a newer cobra regulator/vaporizer. as well as a new lock off valve and new propane tank. Still smells rich but needs choked to run anything over idle, even at idle it helps to have the intake almost completely covered. I did set the valves, checked compression, all the holes were 110-135. valves all moving. Any help would be appreciated.
Ryker
  • Posted 15 Sep 2017 01:49
  • By ryker_c
  • joined 15 Sep'17 - 23 messages
  • Iowa, United States
Showing items 1 - 20 of 41 results.
No problem glad it worked out
  • Posted 23 May 2018 01:05
  • By stam
that did it Stam! thank you!!!!!
  • Posted 22 May 2018 00:43
  • By ryker_c
Smells rich. Has hot spark. Lean it out. Av1-14-2
  • Posted 4 May 2018 13:35
  • By stam
Where do vacuum readings need to be taken from? the test port on the mixer?
I put the spark testors on it, nice crisp blue spark throughout all speeds, even when the engine is coughing and sputtering.
the only thing I haven't changed is the diaphragm and spring in the mixer. I have seen other diaphragms but never another spring? I did put the red spring in the regulator.
This thing has me confused.
  • Posted 2 May 2018 23:48
  • By ryker_c
Yes the tank is liquid withdrawl, we get our propane at the local MFA, everyone else gets it there too. i have used a different tank off of another lift and it acted the same. ill check out the ignition etc and report back. it will be a little bit.
  • Posted 17 Mar 2018 02:17
  • By ryker_c
Same question that bbforks asked, what type of LP tank you have? Is it a liquid withdrawal type?
  • Posted 8 Mar 2018 22:01
Sounds like this is going to require getting back to the basics. You're going to have to take vacuum readings thru the rpm range & install the spark testers to test the ignition.
Where are you sourcing your propane? What type of lp tank are you using? What type of shut off solenoid does your system have?
If you've got a model J impco converter with the correct spring & a new electronic distributor, then it's time to look outside the box. Where did you source the dist cap, rotor, wires & spark plugs. I personally have had no luck with tvh parts in the tune up/electronic realm.
Are you sure the ignition coil is receiving a full 12 volts thru the entire rpm range? All these suggestions are all off the wall but they do rear their head once in a blue moon
  • Posted 8 Mar 2018 03:54
  • By bbforks
I did not get the spark testors for it, I did order a new electronic ignition setup for it and put it on. You all make it sound like thats what needs to be on there, so i have it on there and running with it.
Still does the same thing. Get the spark testors or does the electronic ignition rule that out?
  • Posted 8 Mar 2018 01:35
  • By ryker_c
I would, u went back to points. I'd also get a known good non internal resistor coil. Flame thrower from pertronix is the best imo.
  • Posted 26 Jan 2018 07:01
  • By stam
I still have the resistor, not wired in though, want me to wire it back in when i get the spark testors on it?
Thank you
  • Posted 26 Jan 2018 02:22
  • By ryker_c
get some cheap spark testers. throw them on all 6 and watch as you get to mid-high throttle.
it should have still run with the ballast resistor wired in even with an internal resistor coil.
jump battery positive right to coil +.
  • Posted 25 Jan 2018 10:20
  • By stam
I did end up getting the PN yesterday, ordered it and it was here this morning. Put it in a minute ago, the exhaust is a little better but it still acts the same at mid-high throttle, coughs and sputters until you restrict the intake some. Any other ideas? Was hoping that would fix it.
  • Posted 25 Jan 2018 04:56
  • By ryker_c
The part number for just the orange spring is S2-38 and blue spring is S2-35
  • Posted 24 Jan 2018 08:15
  • By Partsguy5
Check TVH parts. That is where we get ours.
  • Posted 24 Jan 2018 06:59
  • By BREWSKI
Hey Brewski,
I have been looking around for the orange spring like you said. Cant find one. Probably have to get a whole regulator?
  • Posted 24 Jan 2018 04:30
  • By ryker_c
I cant say for sure, Ill have to look. i want to say blue... iil check that out. Thanks!
  • Posted 16 Dec 2017 03:31
  • By ryker_c
Do you know what color spring is in the Regulator? There are two different ones. Orange is for the bigger engines and blue is for the four cylinder engines if I remember correctly.
  • Posted 4 Nov 2017 06:29
  • By BREWSKI
OK I have readings on the exhaust now, no numbers on hand, yet aw at the shop, the carbon monoxide was wayyyy to high.
  • Posted 4 Nov 2017 02:24
  • By ryker_c
No update as of yet, have the lift cylinder off to be resealed. it is running much better now, but still wants choke to run the best, it uses a bunch of propane either way. Thats about all i can say as of yet.
  • Posted 18 Oct 2017 06:04
  • By ryker_c
What's the word? Whatcha find?
  • Posted 12 Oct 2017 00:43
  • By bbforks
Tusk 500PGH16
Maxlion R2D35
