Could anybody write me, what do codes A5, A8,C4,C8,E6 mean?It would be good to have a list of all error codes, could you please send it to me? thanks
Showing items 1 - 19 of 19 results.
Usually these errors are caused by the interruption of the N1 track under the CPU card connector. Good job.
we have a toyota forklift 7FBCU30
showing following error code
CB-1 , 54-1 , FO-2 and 64-1
would you be able to guide us on it... also would be able to forward me error code detail..
thanks
shail Bhandari
EA some problem with MP conntactor ( lift section)
CA some problem with MF and MR conntactor ( drive section ) left and
right direction
-- > open coils , switching transistors for their coils etc...
I suppose , it could be something which is common for all conntactors, so that I thing missing +U to supply them
Hi does anyone have code explanation for EA CA on FBM25 truck is either intermittent or just dead.
I have the same problem. I guess toyota doesn't think about 250lb guys jumping on and off the forklift all day. I have repaired the plastic seat mount for the plastic seat switch several times. I have now taped it up and stuck it under the seat. This alarm is active when the switch doesn't disengage after the lift is shut off. It is to let you know a safety feature is not working properly.
Hello, i have Toyota Heftruck FBMF25. When key is on display is blinking and warning sound ir byyping(B_ B_ B_ ). I see no error code on display.
Mabby someone of you can help me ? Also manual or error list (or any info) for this model would be nice.
e-mail: zilvinas.naudziunas(et)gmail(dot)com
Thanks in advance:)
EDIT
The problem is solved by changing the connection between the battery cells.
But any information about this machine is still needed :)
I HAVE A TOYOTA 8FGCU25
SER=12372
LOWERS REAL SLOW ABOUT A 1INCH PER EVERY 3 SECONDS
CHANGED SAFTY VALVE IN SECOND STAGE CYLINDER
CHANGED LOWERING VALVE LIFT LOCK SOLENOID
ALL SWITCHS CHECK GOOD.7 VOLTS TO SWITCHS
CHANGE HYDRAULIC OIL AND FILTER.
STILL LOWERING SLOW.CAN ANY ONE HELP ME OUT PLEASE.
THANKS
I see the A5-1 code from the driver sitting in the seat turning the key on and off and it just needs cleared and watched. on the other code if you have another truck same model switch the floor boards and see if it follows over to that truck. If so it is the sensor on the floor board if not we have found it in the wiring.
Potentiometer accelerator out range ore defect cable defect
Anybody know what an A4 fault code on an Toyota FBMf25 is.
email [email address removed]
Have a 8fgu30 model forklift the code E AS-1 or E A5-1 is popping up every once In a while what does it mean??
Sorry, but we must be careful because the error codes are displayed on the same series 5FB-6FB-5FBE-FBM-FBMF but sometimes have different meanings, we need to find the fault in another part of the forklift.
Problem with seat switch no GND When take place on seat is going the vork lights out !!!
Regards
John.
I have a Toyota Fork truck 8FGC25 that flashed a code= E A5-1. does anybody know what that would be?
Hello robbo, give us your email.
I had a C8 fault the other day. for anyone looking to save a pointless call out charge try the following:
check wires leading to accelerator pedal in front of truck for loose connection/water. Very easy to do, simply lift forks high out of the way and you'll have access to wires between tyres.
a combination of cleaning and hair drying this area resulted in truck working again!
would it be possible to forward me a list of the fault codes too please?
thanks
thanks a lot John, I did get it.
Hello
A5 is your brake potio defect or wiring
A8 is Fuse f1 defect or wiring on fuse.
C4 drive accelerator potio or wiring.
C8 Speedsensor or the wiring.
E6 pump accelerator potio lifting
Regards
John.
I will send you
John.
Netherlands
