Atlet UNS 140
Hi,
Need some help now.... My Atlet do not want to start at all.
When I plug in the batterycabels it makes one click but the display do not light up.
There is 48V to the main computer and there is power to the "Electronic steering controller" but only 16V, is that ok?
All fuses are OK.
There are three fuses on the computer and those ar OK as well but only power on two of them, anybody know if that is normal?
There are 12 LED (red) on the computer but only 8 of them is lit up...
Can someone please help me get this thing running again I would be very happy :)
Thanks!
  • Posted 2 Aug 2017 05:27
  • By orjan_b
  • joined 2 Aug'17 - 2 messages
  • Halland, Sweden
if you unplug the battery and plug back in right way sometimes the display dont lit up, first thing unplug the battery and leave it like 5 minutes them plug it back on, if you still have a problem check the battery voltage make sure the battery is fully charge lets start with that,if you need more help let me know now to get the nissan password you might have to contact nissan or atlet,
  • Posted 8 Nov 2019 01:38
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
Hello,
does anybody know where to obtain service id and password for Nissan (Atlet) UNS140?
  • Posted 7 Nov 2019 02:37
  • By ivanlinaric
  • joined 16 Jan'11 - 110 messages
  • Zagreb, Croatia
Service technician.
Feel free to contact me at ivan.linaric@okretnimoment.hr
Well if you dont get the display to lite up and see the error codes on the computer is going to hart to know what is causing the problem, but to start check the battery have 48 volts if you dont have 48 volts going to terminal #1 and # 2 coming from the battery the display will not lite up check batt. plugs terminals on the truck side and batt, side if battery is full charge and still no display, replaced the computer
  • Posted 1 Feb 2018 00:49
  • By GUANAJUATO
Hi,
One of the big realys, there is for of them, was broken. I got me a new one and then it worked.
  • Posted 31 Jan 2018 19:13
  • By orjan_b
  • Halland, Sweden
hello ,
did u mange to solve this issue ?
please explain what u ind and wht repairs are done , my atlet is having the same issue exactly
  • Posted 31 Jan 2018 18:44
  • By anas_i
  • joined 31 Jan'18 - 2 messages
  • abu dhabi, United Arab Emirates
Hi try to unplug all the connectors from the computer it might work
if does not work you need to replace the computer
  • Posted 8 Sep 2017 22:27
  • By GUANAJUATO
UN Forklift FB25N1QZ1
Kalmar-Ac P100CXD
Kalmar-Ac P100CXD
Sue Tomic Sue Tomic
