event code 348
Display only shows spanner and will not do anything if I go into events it says 348 can anybody enlighten me thanks.
  • Posted 18 Jul 2017 00:00
  • By Sunnysmile
  • joined 4 Jul'17 - 12 messages
  • Moscowskaya, Russian Federation
I had the same problem, the machine use to run and stall after a short while. I did check on the loose connections especially for the two controller cards and I programmed the machine and it did work well.
  • Posted 24 May 2018 01:55
  • By Juma
  • joined 23 May'15 - 29 messages
  • Nairobi, Kenya
Nyakwar Obuolo
Aichi RX07B
Mitsubishi FD200
Aichi RX07B
Mitsubishi FD200
