Blowing fuse and loss of all power
Hello,
I have a WP2000 jack and couple times now within a few weeks the unit has blown the FU2 - Control Circuit Fuse (the 10A fuse to the lower right of the key switch) Any ideas on what may be causing this? Other than this issue the jack works fine, but when the fuse blows its dead. Any and all ideas are welcome.
Thanks
  • Posted 30 Jun 2017 00:29
  • By darek_s
  • joined 17 Jan'13 - 27 messages
No luck with the harness in the handle. Only part of the harness that had any wear was down at the knuckle and it was only the corrugated loom over the harness. Anybody have any other ideas?
  • Posted 8 Jul 2017 06:58
  • By darek_s
Thank you for the reply. I'll look into it and post back here if I find anything.
  • Posted 3 Jul 2017 21:28
  • By darek_s
That is most likely to be a harness problem. I have replaced many with blown fuse/ travel issues. The biggest problem is...you can't see it until you remove the control handle from the steer knuckle and look up inside. The harness rubs every time you pull down on the handle and eventually short to the truck
  • Posted 30 Jun 2017 22:54
  • By Ifixit
Sue Tomic Sue Tomic
Mitsubishi Logisnext FD25T5M
Nagano NUL120-6
