Code GD
Reach keeps displaying code GD, I've checked the steer encoder, the steer motor. Any ideas on what else it could be?
  • Posted 1 Jun 2017 03:07
  • By BenB
  • joined 13 Jul'16 - 27 messages
My experience with code gd besides steer motor encoder is steer gear box going bad, ring gear loose and spinning on drive unit, steer sensor flag, broken teeth on pinion or ring gear. Good luck
  • Posted 12 Jul 2024 11:01
  • By Sean_Herrick
  • joined 12 Jul'24 - 2 messages
  • Vermont, United States
Seanherrick
Hi, i have multiple errors on display like FN , FH,. Fault in vehicle manager , I have different model vehicle manager but part number same i need a software to install. I have flashware software but i need a package. Thanks
  • Posted 30 Dec 2023 19:34
  • By Atif_Rasheed
  • joined 29 Dec'20 - 28 messages
  • Pakistan
check steer motor gear that the keyway is not sheared on the gear i have had that happen before if not there is a steer module that connects to steer motor possible fault
  • Posted 30 Dec 2023 19:22
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Hi, could you please help me for installing a new vehicle manager in raymond DDRT32 TT. Thanks in advance
  • Posted 30 Dec 2023 16:48
  • By Atif_Rasheed
  • Pakistan
Had the same issue and found the brushes for the motor were worn down very bad and the connatator for the motor was filled with dust from the brushes. Replaced brushes and honed the the connatator. No more issues after that.
  • Posted 20 May 2022 23:41
  • By Kyle_Johnstone
  • joined 20 May'22 - 3 messages
  • Wisconsin, United States
Nice day
I have the same error this computer is a 740dr32tt
I see that it has no direction control
Only one contactor energizes the steering dc motor
What is the address controller
Best regards
  • Posted 17 Feb 2022 00:30
  • By Carlos_Gomez
  • joined 20 Mar'20 - 16 messages
  • GUAYAS, Ecuador
Carlos Gomez
this can be any loose steering parts. when the encoder sees input with no driver input it will code.
i have had the vehicle manager cause this code a few times but more common play in steer linkage, drive unit bearings, or any loose parts that have to do with steering
  • Posted 29 Sep 2017 12:57
  • By kyle_z
  • joined 25 Sep'14 - 13 messages
  • Illinois, United States
I was getting a GD on a Raymond double reach 750 including G4 and 4B. I replaced steering wheel encoder and still problem continued. I finally replaced the steer amplifier and it worked. All codes cleared.
  • Posted 1 Sep 2017 06:03
  • Modified 1 Sep 2017 06:04 by poster
  • By alex_h
  • joined 1 Sep'17 - 1 message
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 33-1200C
