Yale GDP45SVX5 V2514:
Technical Troubleshooting
Fault 524225-0 Truck Disabled
  • Posted 28 Dec 2021 06:24
  • Discussion started by Uriy1
  • Ukraine
Thank you very much, the sensors swapped the code changed 524223-0 I suspect a faulty sensor
  • Posted 31 Dec 2021 16:40
  • Reply by Uriy1
  • Ukraine
Uriy,
Forward transmission pressure greater than commanded. If the code continues to show, suspect failed sensor, bad wire or possible bad connection. You can swap pressure transducer sensor from reverse side and see if the code changes. If it does, bad sensor. Good Luck
  • Posted 31 Dec 2021 07:04
  • Reply by Fishmech
  • Virginia, United States
F. Uchiyama
edition #1234 - 12 June 2025
