taken in water
hello guys. one of my 39x h30d trucks has taken in water in the air cleaner when it was running. don,t ask me how it just did. now it has a rattle and runs like a bag of crap , i am about to stripdown engine looking for a bent valve or conrod but is there anything i need to watch for. diesel VW engine. cheers
  • Posted 20 Nov 2009 05:19
  • By kevin_k
it,s not white smoke its blowin steam out. never seen as much before though but again it clears fine after runnin up and down the shed. customer still cencerned with this steamy situation but i blame the weather
  • Posted 6 Jan 2010 04:54
  • By kevin_k
got truck back together , finally. starts and runs fine but wouldn,t travel full speed.seeked some advise locally and found faulty air mas sensor. changed it for new , now truck travels fine just like before engine damage , but when left over night , when started it kicks out loads of white smoke which clears after a few seconds. tested glowplugs 1-3 read 0.3 ohms , no4 read 0.6 ohms. think i,ve found the problem here but any thoughts would be helpfull. cheers
  • Posted 17 Dec 2009 10:20
  • By kevin_k
thanks mate. i got a book from a guy at work with all the bits and pieces i need so thanks for your time. should be alright with it now. still waitin for parts
  • Posted 2 Dec 2009 03:54
  • By kevin_k
Sorry kev not been back to you due to computer problems,Do you still need the info?
herald
  • Posted 1 Dec 2009 05:32
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Hi kev sorry not been back to you had a few probs this week,you will need new head bolts,I will get you all the rest for tomorrow
ta
herald
  • Posted 27 Nov 2009 06:21
  • By Herald
hi herald. settings for head bolts will be enough to get me going mate. and will i need new bolts. think i,m gonna invest in the right tool for setting up the timing just to be safe.oh and big end torques too please mate
cheers
  • Posted 24 Nov 2009 05:08
  • Modified 24 Nov 2009 22:29 by poster
  • By kevin_k
Hi kev could be a record 2 bent rods quite impressive...
Let me know what torque settings you need i will sort them out for you,As for the cam shaft pulley you may need the timing tool that fits behind the vacuum pump on the opposite end of the cam shaft from the belt,they are available from VW dealers and are not that expensive and come in handy if you come across a snapped belt.
If you cant get the tool its a bit of a guess unless you marked the camshaft before taking of the pulley.
The gas trucks have key drive pulleys,but all diesels have taper fit???
Let me know what you need,
cheers herald
  • Posted 22 Nov 2009 07:07
  • By Herald
i am now the proud owner of 2 bent conrods yes 2. parts on order just need the torque settings and other info for rebuild if someone would be kind enough. thought i was gonna have to take the engine out but the sump cdropped off in situ. i messed up a bit when i pulled off the camshaft pulley, i thought it would be on a key not a taper fit so rebuild maybe tricky
  • Posted 21 Nov 2009 11:10
  • By kevin_k
Good luck kev hopefully you have just got a bent valve,
mr fixit i bet that made him jump out the boat lol..
herald
  • Posted 20 Nov 2009 08:53
  • By Herald
This reminds me of a incident my friend had years ago. He worked for a company that would remove weeds from lakes around docks, etc. They used a flat boat that had a paddle wheel type thing that would cut the weeds and lift them out of the water and place them on the deck of the boat. It was powered by a 4 cylinder motor. They over loaded the boat with weeds, on one side, and it slowly rolled over. The air intake hit the water and went under with the motor running at full speed. The motor blew up like a handgrenade. Everything broke into pieces, block, crank, head. He said it was pure luck no one got hit with the pieces.
  • Posted 20 Nov 2009 07:53
cheers herald , did compression test on truck today.1,2and 4 read about the same but 3 low. gonna pull the head off tomorrow. truck runs but lumpy. i,m always cautious on a different engine. had loads of perkys/mazdas and fords in bits but not a VW..cheers again mate
  • Posted 20 Nov 2009 07:12
  • By kevin_k
Hi kev
The vw is ok to strip nothing you wont have seen before,You will probably find a bent con rod if engine was locked up with the water.
I had a customer do the same,They jet washed the truck while it was running and squirted water into air intake locking the engine.We scrapped the engine and fitted a recon unit..
Cheers
herald
  • Posted 20 Nov 2009 07:02
  • By Herald
Aichi SR18A
Terberg YT223
November 3-4 2026 - Houston, United States
May CapEx Index falls Washington, DC, United States
Tampa Florida, United States
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
