still R20-20P
HI everyone.
I have STILL Model R20-20P S/N 512012015749 YEAR 2004
It ERROR CODE 208,209,and 119
What does it mean.
  • Posted 8 Jul 2012 00:47
  • Discussion started by songyot_v
  • -, Thailand
VIMONTA_S@hotmail.com
Showing items 1 - 15 of 15 results.
it can a lot of reasons for this errors, diagnostic with pc software really need
  • Posted 18 Jan 2022 02:02
  • Reply by tr_doctor
  • Netherlands
Regards
hello my trolley still R70-30 has the same problem it starts but does not want to move can you help me thank you
[email address removed]
Vvv
Vvv
HI nacsand_n
Thank you very much.
  • Posted 30 May 2013 11:35
  • Reply by songyot_v
  • -, Thailand
204/196 - pump motor brushes are worn
Regards
  • Posted 29 May 2013 05:25
  • Reply by nacsand_n
  • Madrid, Spain
HI everyone.
I need help. Its show code. Moter Brushes 204, and 196.
What does it mean.
  • Posted 29 May 2013 00:00
  • -, Thailand
HI nacsand_n
  • Posted 15 Oct 2012 22:29
  • -, Thailand
Brush are worn, check brushes or brush wear indicator inside motors.
Fisrt check fuse F6 in rear relay plate and also can check continuity between white and grey wires in four way connectors located on motors.
Regards
  • Posted 11 Oct 2012 07:25
  • Madrid, Spain
HI nacsand_n
I find the new CODE. It ERROR CODE 203.
What does it mean. please help me.
  • Posted 10 Oct 2012 23:20
  • -, Thailand
HI nacsand_n
I find the new Problem. The car's running slowly. Both forward and backward. Sometimes It will show error CODE 206,207,208,209
You will have a guide or something. Please help me.
  • Posted 11 Jul 2012 16:23
  • -, Thailand
If the gap of toothed gear is Ok, possible bad steering angle sensors inside console. Must replace console.
Also you can check and adjust the error tolerance of steer angle sensors through service address 13e.
01 (small tolerance)
02 (default value)
05 (large tolerance)
Regards
  • Posted 10 Jul 2012 06:11
  • Madrid, Spain
Hi nacsand_n
Thanks for the help. Today I had to check it. Now 208 , 209 is ok
but 119 is not clear. I check the distance between Toothed wheel and Console. However, it does not work. Do you have a solution.
Please help me again.
  • Posted 9 Jul 2012 21:32
  • -, Thailand
Ok,
Error 119 indicates a problem in the steer angle transmiters signals. First should check the toothed wheel under steering wheel, the gap between toothed wheel and console must be 1mm.
Angle sensor are inside console.
Regards
  • Posted 9 Jul 2012 01:46
  • Modified 9 Jul 2012 01:46 by poster
  • Madrid, Spain
THANK YOU nacsand_n
There is one code is 119, not 109. Please help me.
  • Posted 8 Jul 2012 22:48
  • -, Thailand
208= fault in revolution sensor in right motor
209= fault in revolution sensor in left motor
Is not usual both motors fail, check connections, but It's possible needs adjust the distance between toothed brake discs
109= CAN fault. Usuallly appears when any outlets for additional consumers (lights, buzzer, etc..) is not well programmed.
Regards
  • Posted 8 Jul 2012 01:02
  • Modified 8 Jul 2012 01:03 by poster
  • Madrid, Spain
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
Taylor T650L
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
