can some please find out error codes for STILL EXV 12
E1 238
E2 235
E3 234
E4 408
yes this is diesel lifter. this problem has started when the switch on gas pedal stop working and I changed it with oder but it was not wright and then it was some strange noise from lifter. then I got the correct switch and since then this problems continued, before it was all ok. thank you for all info.
R70-30 model is diesel lifter if this is diesel lifter so slonide coil installed on the top of gear box behind brake and exceleretor pedal. Solonide coil used for drection forwerd or reverse.
what is the slonide coil and where do i find it on forklift
Did you check its controll card if done then you should have to check direction switch and slonide coil.
hello I have a R70-30 still manufactured in 2001. it indicates error code 2, 57, 58, 195. if I'm working with it for more than half an hour the error 195 is displayed and the forklift drive is switched off and does not go no forward or reverse until it cools down. I think that something is overheated then the error 195 is displayed, what is the problem?
Hi,
I am working on still stacker model Exv12 one problem creat problem for me Error E1 238 durring running stacker stop then reset it again running
Checked Brake ok
Checked temp sensor ok
Check ckecked all cables ok
I think potentimeter faulty but with out installation of Potentiometer this error comes Why?
Hi Nuna, Thanks a lot for reply.
I'll try it soon.
I'll get back to you with a good result, hopefully.
Hi
This means the tiller potentiometer is faulty. Just replace the new one then it must be OK
