still 3 wheeler B30te drive motor
Didn't get to drive the truck only saw a black comm. Anyone know if removing the drive motor is as difficult as it looks.
Looks to me like the mast and gearbox have to come out.
  • Posted 30 Mar 2009 02:51
  • By dozer
  • joined 22 Feb'09 - 15 messages
When in doubt replace the operator
Thanks for the help
one brush was stuck so bad it came out in pieces. I cleaned the come and replaced the brush. The other brushes were ok. I also found the F1 cable shorted to frame ( from the other motor) pinched under a plate at the back and almost completly broken. add to that, the cut out switches were out of adjustment. By the time I picked the melted copper out of the comm I still had 8 hours in this. At least I didn't have to take the the truck apart.
Thanks again, I like to let people know they're advice was worth while
  • Posted 5 Apr 2009 11:34
  • By dozer
What is the serial #. If it is a later model with a serial # that starts with 324......then it is a fairly indepth job. You must remove the mast, unbolt the drive units from the frame and then separate the motors from the drive units.
  • Posted 30 Mar 2009 22:10
  • By duodeluxe
  • United States
duodeluxe
i don't know this model but other stills. you have to take off the mast remove complete front axle complete. then strip motor out
  • Posted 30 Mar 2009 21:23
  • By Leon_W
  • Tyne & Wear, United Kingdom
Terberg RT403
Elwell-Parker ESI500-36
