Steering issues code 5.182
Hi all,
Can someone advise what the above code is. The unit appears not to be reading the steer sensor. The issue started as intermittent but has progressed to being present at all times. Truck will not start up.
  • Posted 23 Jul 2019 12:28
  • By Julezrobdog
  • joined 23 Jul'19 - 1 message
Jules
- Check the reference sensor
- Steer slightly to the right so that the
crown wheel is correctly positioned
in relation to the reference sensor.
- Check the space between the sensor
and the ridge on the crown wheel
using a feeler gauge. Nominal
measurement:
1.5 mm
- Check if there is any power supply to
S65, 9.8 - 13.5V between wires 95
and 97.
- If there is a power supply, replace
S65.
- Check if there is any short-circuit
between wires 95 and 97, and
also between 95 and the rest of the
electrical system.
- If there is no power supply or short
circuit
- replace M6
- Check the steering angle sensor
- Compare the steering angle to the
angle
- Steering angle calibration
  • Posted 21 Sep 2019 05:29
  • By Radoslav_Pantic
  • joined 21 Sep'19 - 1 message
  • Vojvodina, Serbia
How old is this truck?
There is a known issue that affects some newer ( mid 2017 build onwards ) trucks.
Do you know if this truck is equipped with the older ZF type gearbox OR the newer Kordel type?
  • Posted 31 Jul 2019 01:12
  • By Forkingabout
  • england, United Kingdom
