Steering Column Rebuild
Looking for info on a steering column rebuild for my 1965 Clark Y20 2024 Forklift. Any info on that or other part rebuilds for this lift would be greatly appreciated!
Thanks Drew
  • Posted 1 Apr 2016 06:49
  • By drew_k
  • joined 1 Apr'16 - 5 messages
  • Kansas, United States
I have not yet gone to the local Clark dealer its about 4hrs from me. But I'm going to try and get up there soon to see if they can help me more.
  • Posted 4 Apr 2016 06:38
  • By drew_k
Did you try your local Clark dealer? Mine has books with info on the old models.
  • Posted 2 Apr 2016 05:32
Thanks, that's where I got the rebuild kit. And he had a few pages of info on the steering gear. just looking to see if there's anymore info out there. Thanks
  • Posted 2 Apr 2016 04:43
  • By drew_k
Try Midwest Steering they are pretty good when it comes to these older units. Phone number is 800 237-5048
  • Posted 2 Apr 2016 04:35
  • By Partsguy5
  • joined 13 Jun'12 - 408 messages
Also want to fix the Gas and break pedals. I have replaces the master break cylinder along with the 2 front brake cylinders but there's a leak in the line somewhere and just haven't fixed it yet. The linkage in the gas pedal has never been connected and just wired for idle. Just wondering if there is any repair manuals out there of any kind. Thanks!
  • Posted 2 Apr 2016 04:13
  • By drew_k
The steering stopped working the other day so I took the steering assembly off. The steering Shaft wants to "unscrew" when turning the wheel in one direction and the other it was "****" back down and then turning the wheels. Once I took the assembly off and opened the gear housing I found the thrust bearing in pieces. But not sure how that bearing would keep the shaft from wanting to "unscrew" from the ball nut but I still need to disassemble the whole thing yet might find more damage. But having trouble getting the Pitman arm off. I have found a company that has a rebuild kit for this steering gear assembly made by Saginaw Gear. What I'm unsure of is the process of disassemble and the steps for the rebuild.
  • Posted 2 Apr 2016 04:08
  • By drew_k
What symptoms are you having that a rebuild is required? Not sure parts are going to be available through forklift channels for a machine this old.
  • Posted 2 Apr 2016 01:01
  • By bbforks
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
