Toyota 7FBRE 16-3:
Steer fault
The steering tends to wander to one side
When travelling straight backwards & does
not always respond fully when turning,turntable
Doesn't move.Spins freely when jacked up.
No error codes but proxy switch at turntable
shines red instead of green/yellow??
  • Posted 13 Mar 2014 23:42
  • Discussion started by dieseldad
  • West yorkshire, United Kingdom
hello,
did you solve this problem? I have a 6FBRE12, model 2014 with 800 working hours.
You use the truck without problems, but in some moment the steering is disconnected when you turn left and stops work to that side, but if you turn to the other side works ok. When the error appears, the steer in left direction does not work anymore. this is sporadic, you can use the truck a lot without error, and then the error appears 3 times in 10 minutes.
If you turn off the truck, and then turn on, the error disappears and appears again as sporadic.
  • Posted 17 Oct 2014 03:48
  • Reply by andres_v
  • CABA, Argentina
Always in movement
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
Toyota 8FBE20U
Flesherton, Ontario, Canada
Advance CS7000
Illinois, United States
USD8,000
Dubuque, IA, United States
Louisville, KY, United States
